Sure it looks feature packed but i can't use them
1.)You cannot use DIVX, the only good quality codec I have on my system.
2.) I can't seem to cut files at a certain time
1.) You can use DivX and it works perfectly
2.) Use the "mark in" and "mark out" buttons
(The VDub is only showing a warning sign about using the divx codec, just click yes and proceed!)
http://www.virtualdub.org <- Download the latest version. 1.4.5 -
I hate V-dub as well, other reasons (try capture with an ATI AIW Radeon with it sometime!)...
i have not used it to capture (although i am tempted using my ATI Rage Fury Pro), but i have used it for joining 2 files and it is perfect up to the exact frame.
I just started using it yesterday and I can do the divx encode even with the new ver 4 one. My impressions of it is that the filters suck and I have to fix everything it does in tmpgenc. Does anybody know of any other capture progs that are ofgood quality?
Perhaps you are trying to do too much?
1. You cannot capture and use most filters in real-time.
2. Otherwise, Virtualdub captures video on a VFW compatible driver just fine.
3. Also, the filters in virtualdub are very high quality.
4. You can use DivX with VirtualDub just fine.
5. You shouldn't be capturing in DivX if you want to encode with TMPGEnc anyway.
Regards.
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Some questions regarding Virtual Dub
By smackyourfupa in forum DVD RippingReplies: 3Last Post: 5th Nov 2007, 07:00 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 07:00 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 16:36
