Hey you all.
Followed the guide "How to...SVCD-DVDR".
Demultiplex - Convert the audio to 48 khz MPEG1 Layer2 - Authoring -
and last burning the DVD.
I burned 4 episodes of Dark Angel on one DVD-R brand Verbatim and I have tried one DVD-RW from Sony. Both plays fine on my computer using MyDVD and WinDVD.
On my standalone player, Pioneer 444 I get the menu and when I try to play chapter one I hear 3 secs of sound, still sees the menu, and then I see "search" in the display, another 3 secs of sound, (chapter two). It does this on all 4 chapters/episodes and then returns ready.
Both discs plays perfectly on a 99$ standalone player a friend bought at the mall. He laughs at my 350$ Pioneer 444.
Anyone have any ideas? I want to wipe that smile off my friends face)
thers also the solution
its your standalone
some standalones cant play that format (svcd on dvdr)
theres an sample here to download,
wich you can burn & test if your standalone play
svcd/dvdr or vcd/dvdr
i experienced that almost all cheap standalones plays them
all "high quality" ones have probs here too, even with regular
burned dvd-r -
many stand-alones can't handle svcd video on a dvdr medium. Another possible solution might be to encode to a dvd-compliant CVD (352X480), (presumably your audio is already at 48 khz, right?) and then author to DVD and try it. Make sure your stand-alone is able to play vcds, svcds, and cvd's of course (and check the media your stand-alone can play and so on and so forth)...
http://www.vcdhelp.com/dvdplayers.php?DVDname=444&DVDselect=&Search=Search
one user reported that it worked great
Download my sample here www.vcdhelp.com/dvd#sample and test if it works, that svcd is made directly from the guide on this site. -
You may wan tot check to see if your player can play the DVD-R, some can't play anything recorded on the DVD-R format, I have two Panasonics and they both pl;ay DVD-R's however my Samsung M301 will not play the DVD-R disc.
Aloha
Bud -
Thanks to everyone replying,
I really did a lot of research here before buying the Pioneer 444. Read alot of the compability reports here at vcdhelp.com. My whole idea was to put my SVCDs on DVD discs.
Have ripped DVDs and burned with Nero, works OK on the Pioneer 444. It also plays SVCDs and VCDs, never had any problems. Had a Samsung earlier and had audio-sync problems on 8 of 10 SVCDs. Gave it away.
I also have a Pioneer DV909, it plays VCDs but the SVCDs it plays with picture on only half the TV screen, -vertically. Keeps it because it also plays Laserdiscs.
I have not tried to convert the audio to PCM. Anyone know if this would help?
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 20:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 02:32
