When I capture in videostudio it forces me to capture in type 1 video. Is this a codec and am I losing anything with this type 1 video scheme. I would like to capture using the huffyuv but can not with my firewire card.
There is no loss in quality between Type 1 or 2 AVI. I cant give you a technical breakdown of the two types, but they both capture equally well.
As for VideoStudio, I am pretty sure it will not allow you to use any compression codec (ie Huffy or PICVideo), besides the one that is comes packaged with its software. Also, I believe VideoStudio captures uncompressed AVI, so therefore no Huffy or PICVideo supported.
If you want to capture compressed AVI and save yourself some disk space, try:
VirtualDub or AVI/IO and remember to download the compression codec HuffyUV and/or PICVideo.
One thing I just thought of. I believe VirtualDub does not support Firewire capture.
Editing AVI type files
By Robertos in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2011, 11:22 -
video file won't play. need to know what type it is - what codec?
By chriscaton in forum Video ConversionReplies: 7Last Post: 12th Jan 2010, 09:20 -
Mencoder Batch File - Converts Every Codec type
By peterbuilt in forum Video ConversionReplies: 5Last Post: 28th Jun 2008, 07:41 -
Codec type mismatch for converting MP4 to FLV
By swashbuckler75 in forum ffmpegX general discussionReplies: 2Last Post: 24th Apr 2008, 13:28 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 21:16
