I've been looking through the list under the capture cards but i want some advice on a good low budget card to get. Its for my dads cpu (pretty slow) 400mhz amd with 128mb ram. All he wants to do is take some video tapes and convert them to vcd's and eventually dvd's. I know the system is too slow for dvd's now but it should work for vcd's. Any you would suggest?? I have an older ati aiw 128 pro but its only 16mb and sucked for capturing. Plus my aiw 7500 won't work cause he doesn't have agp.
your processor is a major problem.
You can't do direct to mpeg software captures, even though ATI says you can, that's bullsh!t.
You need a MPEG Hardware board or a simple tv tuner and capture to AVI and transcode.
Since your CPU is slow, you might want to explore a hardware encoder. -
Try Pinnacle Systems MP20, cost around $250, a real-time MPEG-1 or 2 capturing and hardware encoder with acceptable quality (especially MPEG-2). Since this is a hardware encoder, you system speed is not important.
please help me choose software. Open source or low budget stuff
By phoenix777 in forum Newbie / General discussionsReplies: 1Last Post: 31st Aug 2011, 09:25 -
What is the best capture card on a small budget?
By 707Gaming in forum Newbie / General discussionsReplies: 5Last Post: 12th Jul 2011, 07:42 -
Advice Needed on Making a Low Budget Instructional DVD
By PleaseHelpMe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Mar 2011, 20:11 -
Low profile capture card options
By GLE3 in forum Capturing and VCRReplies: 7Last Post: 30th Mar 2010, 18:59 -
Low budget DIY
By guns1inger in forum Off topicReplies: 2Last Post: 17th Sep 2007, 03:31
