I'm getting "could not open this file with directshow" trying to merge & cut in TMPGEnc.
It's a SVCD that I just created with TMPGEnc .. is there some reason it cannot open it's own files?
It does allow me to view other MPG's.
All I want to do is edit it down to size. I tried M2-Edit, but it only allows 2 minutes... and i dont see anyplace to put the serial number so I'm guessing you have to download a non-demo to use it.
If there's a fix for this problem, or another program I could use, I'd appreciate a little help, thanks.
I just added the VFP .. thing.
Still not sure what it is but no errors now.
BUT I cannot see the preview in the Merge&Cut Edit window.
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 13Last Post: 22nd Jul 2016, 21:39 -
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 18:35 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
For those who face the "windows media player cannot open this file" problem
By sanosuke in forum Software PlayingReplies: 0Last Post: 1st May 2011, 08:00 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 17:40
