What are all the pins for? Does your audio go over that same cable too?
No, only video is found on an S-video cable. The four tiny pins do all the magic. S-video has a separate 75-ohm cable for chroma and for luma. Therefore, two pins are for chroma, and two are for luma. Two pins are used for each to supply the signal (one pin) and ground (the other pin).
auxiliary power connector on aiw2006?
By greenbag in forum ComputerReplies: 8Last Post: 2nd Sep 2010, 18:37 -
What is this power connector ?
By Noahtuck in forum ComputerReplies: 3Last Post: 14th Jan 2010, 15:32 -
Motherboard 8 pin connector...
By rubberman in forum ComputerReplies: 15Last Post: 5th Jan 2010, 21:24 -
Sync issue with Grey's Anatomy S2 (R1)
By rmna in forum DVD RippingReplies: 2Last Post: 4th Dec 2009, 20:44 -
How does the USB connector work?
By maxxDV in forum DVD & Blu-ray PlayersReplies: 7Last Post: 14th Sep 2007, 12:29
