Hi all,
I just searched for an answer to my question but couldnt find anything relevant. I'm using an ATI TV Wonder VE card to capture VHS off my VCR. I have my VCR running through my stereo and my stereo running to the Line In on my Sound Card.
The TV Wonder card has audio inputs on it.
Should I run the audio in through my soundcard through my stereo the way I have it, or should I run the audio in through the Capture card directly from the VCR?
Thanks for any advice. I just dont want to have audio sync problems while capturing.
Thanks,
Chris
TV Wonder VE only has audio out(1/8in. mono),Use receiver to soundcard if rec. has Dolby Pro Logic output.Dolby 5.1 cannot be encoded on VCD.
You're right, I dont know what I was thinking. I thought I had my audio running into my TV Card bt it's not. Brain must be fried from reading so much about all this stuff. Thanks.
I still would like to know if it is possible to run the sound from the stereo into the soundcard and get better audio capture, or would I get better capture running directly from the VCR. Guess it's time for some experimenting.
Is there a capture utility like tunebite that will capture 5.1 audio?
By yoda313 in forum Capturing and VCRReplies: 5Last Post: 18th Dec 2015, 02:45 -
How to capture audio only
By bigbomber5 in forum EditingReplies: 2Last Post: 1st Sep 2010, 14:38 -
What about audio capture?
By Fryster in forum Capturing and VCRReplies: 3Last Post: 25th Dec 2009, 09:47 -
capture not getting audio
By bbxrider in forum Capturing and VCRReplies: 3Last Post: 7th Aug 2009, 13:00 -
How to - Capture DVD 5.1 Audio - Coaxial vs. RCA Audio
By JBredensteiner in forum Capturing and VCRReplies: 3Last Post: 13th Jul 2007, 12:46
