    Aug 2002
    Charlotte, N.C
    When converting files in Nero, it takes hours and on one occasion a day and a half to convert from avi. to mpeg. Is this typical or is there something that I am not doing right? I appreciate any suggestions that may speed this up.
    Aug 2001
    Västerås, Sweden
    i have only used nero to convert ones and that didnt tke that long. the result was crappy too, so i wont do it again.
    i have a guide for it at my site, and there are guides here too i guess.
    Well, I am the slime from your video.
    Oozin' along on your livin'room floor.
    Aug 2002
    Malaysia
    MPEG encoding very cpu intensive job, there are 2 way to speed up :-
    1. Lower the bitrate and video quality
    2. Upgrade your cpu
  4. One piece of advise DO NOT USE NERO TO ENCODE. Use tmpgenc to encode your mpeg, then use nero to burn. Nero is a good burning application, but a lousy encoder.
    Craig
  5. just to give you an idea the average 700mb divx film takes 4 hours to convert on my pc.
    This is going to svcd 2 pass, vbr to fit 2 disks.
    pc spec is p4 2.2ghz 768mb ddr 120gb 7200 drive
    this is using tmpeg plus
