What is the best method of ripping DVDs, from vcdhelp.com?
Results 1 to 16 of 16
actual dvd->smartripper->dvd2avi->tempgenc->nero->burned SVCD
wouldn't say it's the best...but prolly the easiest and better (if not the best) quality
I have a problem with DVD2AVI. When I save project it creates a d2v and a wav file. Then the tutorial says to use the d2v file as the video source in tempgenc, but it is not excepted by the program. Although the wav file works fine.
You probably have deleted the VOB files from your hard drive, since the D2V file only maps the sync from the sound and the video.
Or maybe you dont have the plugins enabled on the appz.
One suggestion is to use the latest versions and put both appz in one folder.
Hope this helps
|Mr_LoCo|
ReSpEcT -
What he means (I think) is that you must have the TMPGEnc VFP and the DVD2AVI.VFP located where the TMPGEnc has been installed, without those files, TMPGEnc can't identify those file types, and that is why you are getting problems.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Believe me there is alot I don't know!, like why on earth people are still using Microsoft (Non)Operating Systems for example, it's an issue I just can't figure out ;o)
and I can also make mistakes like everyone else, and i've learned alot from Adam and Baldrick and vitualis and god knows how many more!
I'm just glad to help whenever I can, I know it sounds weird in these days where everyone usually helps only if they get something in return, what can I see, i'm weird ;o)
Best Regards,
Sefy Levy,
I'm just glad to help whenever I can, I know it sounds weird in these days where everyone usually helps only if they get something in return, what can I say, i'm weird ;o)
Best Regards,
Sefy Levy,
im working on the transition to redhat linux!
it's a matter of getting to where i can do everything in linux that i can in windows!!
and i dont know how to do this stuff in linux, and i don't have my dvdrom drive yet either.... =\
THIS IS HARDCORE -
In my experience (300+ SVCD movies and growing) Windows 2K works the best w/ the ancillary tools I've outlined in prior posts.
Need help? just ask....e-mail me
CR
Job security is knowing 99.9% of the world is full of PiN HeadS!!!! -
Hi Mr Poopyhead
What do you think is the method to get the best quality rips?
Furble
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
IMHO, for standard compliant VCDs, FlaskMPEG --> Panasonic MPEG Encoder plugin yields the best quality, and is also the easiest method to use (especially if you want to use non-English soundtracks and subtitles).
DVD2AVI --> TMPGEnc yields similar video quality but is harder to master. However, it is definitely faster.
For standard VCDs, the best two mpeg-1 encoders to use are probably the Panasonic MPEG Encoder and TMPGEnc. There are two camps on which yields superior video quality. This is as these two encoders emphasis different things. The Panasonic MPEG Encoder yields smoother softer video, while TMPGEnc yields sharper, but blockier video. Which one looks "better" really depends on your own eyes.
Regards.
Michael Tam
w: Morsels of Evidence -
Did you mean this one for SVCD's?
If not, which way is best for SVCD's?
Furble
[quote]
vitualis, wouldn't the world be a better place if someone put all the features and quality of tempgenc together with panasonic cce ;p
Furble, I don't make SVCDs so I can't really tell you which way is best.
poopyhead, I agree with you totally! If only the creater of TMPGEnc had made it open source...
Regards.
Michael Tam
First Time Ripping...Looking for advice...
By zagro002 in forum DVD RippingReplies: 10Last Post: 18th Apr 2012, 23:07 -
Any advice for ripping a badly scratched disc?
By Bix in forum DVD RippingReplies: 27Last Post: 6th Jun 2008, 12:11 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2008, 23:20 -
Need advice on ripping Region 2 Lost Highway DVD please.
By jwnulife in forum MacReplies: 17Last Post: 2nd May 2008, 18:13 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 22:39
