hi,
i got avi video which properties is when played in WMP 8:
Audio Codec: MPEG Layer-3 Decoder
Video Codec: Microsoft MPEG-4 Video Decompressor
i want to convert it to MPEG-1 "VCD".
i used TMPGEnc and Vegas Video 3.0 but both of them doesnot recognized the video "picture", they just recognized the Audio so if i converted the avi ,i will just get mpg file with sound only.
i downloaded all Divx codecs 5 , 4 and 3.
so what is the problem thanks.
well NIMO CODEC PACK V 5.0 BUILD 7 was great to slove this problem and now i can encode the avi.
I'm having the same problem. I had Vegas Video and the latest codec from Divx.com. When I'd try to import a divx avi into Vegas, It would load two tracks - one for the video and one for the audio. The audio was fine, but the video track was all black.
So I downloaded the NIMO codec pack and installed lots of stuff from in it. Now when I try to open a divx file, the video loads fine, but the audio doesn't. It doesn't even create a track for the audio. I am, however, able to open a standalone mp3 file. It just seems to not be able to open the mp3 audio in the divx files.
What components from the NIMO pack did you install? Perhaps I missed something, or installed something that I shouldn't have.
Thanks,Jack -
Had a similar problem some time back.It just seems to not be able to open the mp3 audio in the divx files.
Try this.
1) Uninstall all DivX codecs
2) Install DivX 3.11 alpha
3) Install DivX 5.02
4) Reboot.
Solved it for me. -
hey,
well i got the same problem with some Divx but i use TMPGEnc Plus instead to convert this type of avi and they works good.
note: i got the link of TMPGEnc Plus but i can't give u it here, i can email it to u if u want. -
samer,
I wonder if TMPGEnc PLus can solve my problem....
I have some mpeg and DivX videos that I like to burn them onto CDs so that I can view them on my DVD player. My DVD player can play VCDs. So TMPGEnc Plus is all I need? Or do I need some other hardware/software?
If it is so, please email me the URL if it is not too much trouble.
Thanks.
substring
substring0@hotmail.com -
Nope. This didn't help. I uninstalled everything divx, then reinstalled, rebooted, and still have the same problem. Thanks for the suggestion, though.Originally Posted by VaporJack
I downloaded the 14 day trial version of TMPGEnc Plus. I had used TMPGEnc in the past. It worked sometimes, but was very buggy. It crashed... a lot. Often it would crash after having encoded 75% of a full length movie - after about 45 minutes on my PC!
TMPGPlus seems to be the same software with a wizard added to it. I encoded one AVI to VCD with it, then started a second, and I got a system message popup that read something like, "Error -547638201 0431002." When I clicked OK, the same error popped up. This happened again and again, with no end in sight. I had to kill the process in Task Manager.
I'm a software developer, and I must say, the user should never see anything like that. But that's just my gripe. I don't mean to come off as a jerk, I'm just surprised that the author is now selling this product when it doesn't seem any better than the old free version. It just has a wizard now.
My real issue is that I still can't open any of my AVI's in Vegas Video...Jack
how could i add arabic subtitle to avi movie?? plz help!
By abuelbeel in forum SubtitleReplies: 1Last Post: 20th Apr 2009, 14:44 -
Cant seek my encoded divx avi's with HW players ... plz help
By samykoka in forum Video ConversionReplies: 2Last Post: 17th Mar 2009, 14:19 -
ADVICE needed plz! As of Feb 08, best format to ripp DVDs? TIA.
By carapalida in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2008, 12:11 -
converting avi to mpeg-1 help plz??
By darealest1 in forum MacReplies: 5Last Post: 12th Jul 2007, 22:43 -
Converting RMVB Into AVI with SUPER??? PLZ Help
By sandman423 in forum Video ConversionReplies: 18Last Post: 16th May 2007, 12:18
