I'm trying to take a logo out of a video file. However the area comes out all blurred and very noticable. I'm not sure If I had all the settings right but it shouldn't be so blurred with an alpha-blended Logo.
Have you read Hilljack's tutorial on DeLogo? It's well done.http://hilljack.vampirez.com/delogo_00.htm
DeLogo works best on semi-transparent, stationary logos---Something like the Disney Channel logo, or AMC. If the logo has opaque areas, blending occurs to obscure it, making a blurred area where the logo was. Unfortunately there isn't anything---yet---that can fix opaque or animated logos satisfactorily.
You might want to try manual sampling with a few bright frames and a few dark frames (pure black & pure white seem to work the best). I know if you do auto sampling and there are segments in your avi where the logo does not appear, it is unsatisfactory.
Tweaking DeLogo is time consuming. Oddly, I'm having particular problems with Black & White material---probably my inexperience.
Removing Logos using DeLogo vdub filter
By Matt D in forum EditingReplies: 67Last Post: 6th Apr 2016, 11:26 -
Virtual Dub delogo output file help
By Rogert in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2011, 13:25 -
DeLogo HD AVI video problems
By DirtBikeMike in forum EditingReplies: 1Last Post: 14th Jan 2010, 17:45 -
Merits of the delogo filter
By lordsmurf in forum RestorationReplies: 26Last Post: 10th Dec 2007, 07:09 -
Question from Barnabas about Delogo.
By Sean_ve99 in forum EditingReplies: 29Last Post: 2nd Aug 2007, 14:46
