and also top or bottom first??? how do i determine what my source is and what will making this setting wrong do to affect my vcd?
VCD is always progressive. If your source is MPG2 you can load the file into Bitrate Viewer and it will tell you alot about your MPG2.
If you are using TMPGEnc, just load up the template for VCD. Very simple, very easy, very very. -
So when im ripping a dvd to vcd i always choose progressive no matter what? And what does this top or bottom field first setting mean?
ps. sorry if these are dumb questions -
Well when using TMPGEnc and loading the VCD template it will select these options for you. If you are using another program to encode that does not use templates, you can load your VOB into Bitrate Viewer to see which settings you would pick. Bitrate Viewer lists all the specifications of a MPG.
How can I know if Avi is progressive or interlaced ??
By apalace in forum Newbie / General discussionsReplies: 17Last Post: 8th Feb 2012, 14:20 -
NTSC : progressive or interlaced
By mathmax in forum Authoring (DVD)Replies: 54Last Post: 2nd Feb 2012, 07:06 -
Progressive Vs Interlaced?
By shagratt71 in forum Video ConversionReplies: 4Last Post: 26th Dec 2011, 09:22 -
Progressive and Interlaced Chroma -- again!
By Anonymous344 in forum Newbie / General discussionsReplies: 6Last Post: 23rd Apr 2011, 07:14 -
Interlaced or progressive
By rank in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2010, 16:41
