Hi EXPERTS!!!
I have tried several methods for getting a dvd to a divx avi.
The latest id DVDx programm.
According to DRF analyser i get an exelent result :
DivX DRF Analyzer Report!
Resolution: [ Width: 640 Height: 272 ]
Frame Rate: 25.000 frames per second
The Video has 125226 frames [ 01:23:29 ]
Average Frame quality is HIGH
Standard Deviation: Quality is HIGH
Image Resolution is HIGH
There are NO frame drops ( NO drops is better )
This video may have some frames with VERY POOR Quality
Performance Caracteristics:
Macroblocks per frame: 680
The Width is multiple of 32
Kilobits per Second: 1844.26
Kilobits per Frame: 73.77
Kilobits per Macroblock: 0.108
Bits per Pixel: 0.43
Only some poor frames...
My problem now is the fact that i set the framerate so high , i got a verry big avi.
1.4 gig for a 83 minute film... To mutch. should be +- 700 Mb.
Anybody have a advise for changing this?
You need to use the "Zoom" feature in DVDx's Output Settings. Here, you're able to adjust the aspect ratio to Widescreen, Full Screen, Pan Scan, and Medium. All can have various effects on your movie.
The best thing to do is to load your movie in first. Then, use the Slider at the bottom of the Main Screen to slide to a random point in your movie. Open the Output Settings Window and try selecting different values under "Zoom". This will in effect allow you to see what your movie would look like using different Aspect Ratios. You can set your video bitrate to
1150 and click on whole button for high quality but will have to be on 2
cds. You found out 700mb cd is squishy if you try wide screen it might help. You can use studio 7 to add file to a movie to to show you made it
or you can use it to cut some credits out that may work to.
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 22:57 -
DVD to XVID using DVDx 2.20
By Immortal25 in forum DVD RippingReplies: 0Last Post: 2nd May 2010, 06:20 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 01:53 -
New DVDx InfoTool is out
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 22nd Dec 2007, 08:32 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 14:17
