In so many posts people are very happy with spruceup. I search high and low for SpruceUp and come up empty.
What other authoring/Burning app is recommended now that Spruceup is not available to us newbies. I need to deal with two types of files.
1 - My captured files are mpeg2 (compliant i think) captured from DVD Creation Station or from a Matrox RT2500.
2 - Ripped DVD using CladDVD XP which results in the VOB type of files.
I tried nero and it seemed to only want the VOB type of files.
Is there an author/burn app that can handle both types of files and that most people like?
Thanks for your assistance and wisdom.
SpruceUp trial is here http://www.afterdawn.com/software/video_software/dvd_tools/spruceup.cfm
Since they no longer sell SpruceUp I guess it's okay to use cracks
NO IT IS NOT.
I've also used a friend's programme called ReelDVD. I don't know where to get this, but it seemed like a good programme.
edit by baldrick -
Thanks Circleking, but when I go to the link
all download capabilities have been disabled. You would think that they would get rid of the page but they must like to torture us.
Anyway, I appreciate the help and I will look into ReelDVD now. -
Originally Posted by circleking
You aren't very clear what you want the authoring program to be able to do, but some affordable options are Ulead movie factory (cheap), ulead dvd workshop (noticeably more $), and newly released pinnacle studio 8 (which is also an editing package).
And note I don't think any authoring program will take VOB files you have ripped as input. The authoring program GENERATES vob files. I don't know much about how to burn vob files. -
Originally Posted by POLISHED_ARROW
Oh BTW sorry about the link baldrick. Should have asked first.
I just checked the Sonic website that has ReelDVD. They want $1500 U.S. for it. VERY pricey. -
I got ReelDVD with Scenarist and DVD informer from my arab friend.
I see now I've come into some good property.
Anyway, from what's i've read, ReelDVD is inferior to alot of other programs. -
Thanks circleking
Based on your reassurance I went back to
for the 5th time and looked the page over real good. There are blank places on the page. I moved my cursor very carefully across the blank spots and wouldn't you know it, at times it turns form an arrow into a hand. There are no buttons, or boxes, or text, where the buttons should be, just blank white page. I guess my IE 5 doesn't view the page properly. I clicked and a "Send This To a Freind" box pops up. So, I tried again and got the hidden download button.
Thanks for sticking with me.
I did have reasonable success last night with Movie Factory.
SpruceUp will get tested next.
Half-Life 2 5.1 Problems
By AuroEdge in forum ComputerReplies: 10Last Post: 28th Apr 2011, 10:34 -
DVD Burner life
By hibbs in forum DVD & Blu-ray WritersReplies: 7Last Post: 23rd Sep 2009, 15:23 -
Good Battery Life
By Arlo in forum Portable VideoReplies: 2Last Post: 22nd Apr 2009, 13:52 -
The secret life of the penguins
By Midzuki in forum Off topicReplies: 1Last Post: 29th Jul 2008, 07:02 -
Vista has a life of its own?
By VideoGeekUK in forum Media Center PC / MediaCentersReplies: 6Last Post: 1st Feb 2008, 11:07
