  1. What is the best way to do this and the cheapest? A guide would be helpful.
    Herts
    That depends on your graphics card. If it already has TV out then just buy a long (probably S-video) cable and a Scart converter which will allow you to input bith the TV signal and the separate sound into 1 input for you TV.
    Suppose it also depends on the location of your TV and what inputs it has.
    "It's better to burn owt than to fade away."
    Yorkshire Ripper
  3. Chris S ChrisX's Avatar
    Jan 2002
    Some dude from Sydney
    BEWARE OF MACROVISION: No picture for the movie from the computer.
