I am following the instructions on how to burn Bin with Nero
The question is, the last instruction says
'Select write speed and so and last hit Write'
What write speed should i select and does this have an effect on quality?
I will never learn
Assuming that your DVD player was designed to read CD-R/W media, AND your drive and discs are rated correctly, then you should be able to burn at max. speed with no issues.
If your player isn't designed to read CD-R media, then it has been noted by many people that burn speed can affect the readability of the disc on such machines.
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
