Hi i Have a Grand Vcd2000 Card.
My problem is. My mpeg1 films have like a shadow (gost)
if i take them in VirtualDub and step frame by frame then i can see whats happen i the next frame. (it's look like the next b frame is merge over the Current frame)![]()
Does it sound like hardware bug or do you have the same problem..
Does this only happen during high motion? If so, that is a normal side effect of the mpeg compression. If it happens during static images, I have no idea what it is. However, the shadow line effect is normal with this encoder during high motion.
I only happens then i Capture Or wiev Live motions
Ok thanks for the reply
PS. Skittelsen i can see that you have made a review of the PVR-250 does i have the same shadows as the winbond chip.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
