when stepping through my video in TMPG (source frame range), I noticed that every few frames there is an immense amount of horizontal distortion in areas of motion. Is this normal or should I be doing something about it. I have to say I havn't really seen it in my finished products, but I kinda remember it having something to do with interlaceing and don't want to overlook something that I may be missing.
Please let me know if this is something I should be dealing with, or if it's normal.
Roveer
i've had some problems w/ lines in my rip b4...yea...u're correct..it has something to do w/ interlacing cuz if u use dvd2avi w/ forced film on...then u're basically forcing the movie to be progressive even though it might be progressive, interlaced, or hybrid...but anywayz...if u c lines in yer rip...try using the "de-interlace" in tempgenc...also in that filter option choose "blend"...that has worked for me..
There are 12 different 'de-interlace' options. Wondering which one to use, or how to go about figuring out which to use.
Roveer -
read post more carefully
Dark Horizontal Lines
By daave in forum Capturing and VCRReplies: 4Last Post: 14th Aug 2012, 15:26 -
Horizontal distortion lines
By hyku1147 in forum Newbie / General discussionsReplies: 5Last Post: 27th Nov 2011, 10:02 -
Horizontal Lines Appear In DVD
By Mark-Leon in forum MacReplies: 33Last Post: 17th Oct 2010, 10:23 -
Horizontal Lines - Converting
By jooleyen in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2008, 19:59 -
Help - Horizontal Lines
By Hiram_Abif in forum Newbie / General discussionsReplies: 8Last Post: 9th Aug 2007, 12:06
