what program do I need to do this and how would I achieve this? I really need help as I'm on a tight time budget. I got the sequel to 'once were warriors' on DVD from new zealand and i need to create a vcd so that it can playback on us dvd players. Any help would be greatly appreciated! Thanks in advance!
The old pc dont care if its Pal or NTSC but your standalone will...As long as the DVDrom drive on your pc can play the DVD (may have to change the region) you should have no problem using Smartripper, dvd2avi and tmpg....the only thing the dvd is needed for is the first step with smartripper (may take an hour at most for that part) after that all the movie files are on your hard drive and you can take your time.
Look at http://www.vcdhelp.com/sefy/?id=ClassicalGuide.html
for directions. -
so the vcd's palyback is not affected by the original region format of the dvd? i.e. If I burn a VCD from a pal3 format it should play on my ntsc dvd player? (assuming that the player is capable of reading cdr's).. let me know! Thanks!
No...What I meant was you should be able to play on PC dvdrom drive cause it does not care if its pal..and you can usally change the region via your software.....That will allow you Rip the DVD ( decrypt and save as VOB files) to your hard drive. Then you run those through DVD2AVI which will generate two files, one that is the entire sound track and one that allows the vobs to be used by TMPGenc. Its with TMPGenc that you decide if you want a VCD or SVCD in pal or ntsc.....TMPGenc will encode the files into a compatable mpg video file....That will be burnt with a program such as NERO to VCD format and then you can watch on your stand alone DVD player....if it supports VCD.
Hope that was clearer.....
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
Newbie needs to convert NTSC VHS tapes to PAL DVD
By mcullen8320 in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2008, 13:51 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 02:22 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
Newbie post - Recommendations for VHS-DVD Conversion.
By Mysticle31 in forum RestorationReplies: 20Last Post: 8th Jul 2008, 00:51
