In the tests I've been running, I keep seeing this error in the encode logs. I'm targeting SVCD, but at non-standard bitrates and GOP structures. How can I identify the location of the problem and fix it? Should I even be worried. The error message comes with a packet number, but since my brain doesn't mux, the number doesn't help me much.
bah... nevermind. Isn't SVCD VBV 224? For some reason if you use 0 (automatic) TMPG uses 112, even when an SVCD System Stream is selected.
The VBV buffer size may be too small. Yes, you should be worried, the MPEG may not playback correctly on a standalone dvd player.
To answer your next question: No, there is no good way to change the VBV buffer size without reencoding. But you may try the MPEG tools "VBV opt." of TMPGEnc Beta12 (only this version has that tool). It helped me to "repair" some XVCD.
Avidemux multiplex using VBR MP3 "looses" ABR value according to Mediainfo
By ekred in forum Video ConversionReplies: 0Last Post: 25th Oct 2011, 06:39 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
DVD Lab Pro Error: "Read data size is over the buffer limit"
By Motinha in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 02:49 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
