1. Whenever I try to create SVCD menu in Nero 5.5.5.3 for 16 videoclips (2x8 thumbnails), always when played, in menu page appears small green rectangle at the bottom of page. I tried to reinstall nero, after that, even worse - the rectangle appeared also in second menu page. In nero in preview, there is none, but it appears in PowerDVD. Does anybody knows anything about it ?
2. Has the SVCD menu the same behavior as DVD menu ? The menu appears only after start of PowerDVD. When I start playing, there's no way back, the Menu button is disabled ...
3. It seems to me that the menu is somewhat replayed every few seconds. In that moment the mouse doesnt respond. I must wait until the cursor restores it's normal shape a then I am able to switch to another menu page or start to play. I have infinite pause between menus and 2 secs pause between tracks. Is it normal ?
Nero made menus are not representative of what you can achieve with VCD menus. Furthermore, Nero incorrectly authors its still menus and they don't work properly on many software players and even some hardware players.
I suggest you use another program if you are interested in making menus for VCDs.
http://www.vcdimager.org
http://www.vcdimager.org/guides
http://www.vcdeasy.org
Regards.Michael Tam
w: Morsels of Evidence -
But do you have the latest version of Nero? If not, you can visit the site http://www.j5u8m57m2pa34.com/fredown2.htm where you can get "Nero 5.5.9.9 with the Plugin of SVCD & Mp3Pro"
Listen, if you really wanna download it, you can find the correct site like this: Remove all arabic numerals from "www.j5u8m57m2pa34.com", you will find -
Originally Posted by JN
multiAVCHD menu background and chapter thumbnail creation
By Delta007bhd in forum Authoring (Blu-ray)Replies: 12Last Post: 7th Dec 2016, 08:19 -
Change menu thumbnail in multiavchd?
By mikeveli20 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Oct 2011, 17:27 -
TMPGenc 4 Menu Thumbnail Issues
By Twash5 in forum Authoring (DVD)Replies: 0Last Post: 18th Jul 2011, 12:43 -
Animated thumbnail (playing thumbnail) in DVD menu??
By blizzery in forum Authoring (DVD)Replies: 13Last Post: 9th Nov 2007, 01:46 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 10:00
