I was wondering if there is any difference between burning an MPEG2 as Frame-based or Field-based when you are going to burn to a DVD.
I know that in the past you would encode at Frame-based when you were creating for Computer use only and Field-based when creating for Television viewing.
But since I will be creating DVD's, will it make any difference.
I ask this because my Ulead MSP 6.5 uses their MPEGNow MPEG codec that burns well as frame based but not well as field-based. Others have reported the same findings.
Thanks for the feedback,
Dezine (Michael)
Closed Thread
Don't post the same question in several forums!
http://forum.vcdhelp.com/viewtopic.php?t=107212
Regards.Michael Tam
w: Morsels of Evidence
What does a time based corrector actually correct?
By Rudyard in forum Capturing and VCRReplies: 15Last Post: 26th May 2010, 07:45 -
Dye-based vs metal-based: which will last longer?
By RedZone in forum Authoring (Blu-ray)Replies: 11Last Post: 11th May 2010, 22:30 -
what is the meaning of these ? frame based, lower & upper field first.
By khalid81 in forum EditingReplies: 3Last Post: 15th Jun 2009, 12:27 -
Best HD Flash Based Camcorder for $600
By Mike82 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 9th Jun 2009, 10:59 -
Any HARDDRIVE based divx players?
By DVantrease in forum DVD & Blu-ray PlayersReplies: 17Last Post: 29th Jun 2008, 18:54
