    Sep 2001
    Indianapolis
    Ive been trying to rip Scooby Doo original mysteries and cannot get past 22%. Ive used smartripper, dvddycrypter and clad dvd xp and cannot get past the 22%. I rented movie from blockbuster, so I went to a different store and rented it and its the same problem. Im trying to make VCD have been doing it for about 6 months now with great success and help from Sefys guides. Any help is greatly appreciated
    Aug 2002
    scotland
    I have had a similar problem with some disney films .When I ripped the film to disk and then used DVDx the second half of the film was just a black screen .However when I used the file directly from disk all was ok .
    I use DVDx with the LSX plugin to create SVCD with very good results almost as good as original no blocks .Smartripper did say there were encripted files so I take this is what caused the problem.
  3. Make sure you have a functional ASPI Layer installed, make sure it's v4.61 Build 1021, it's the best and least troublesome and works on all OS's out there.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
