Hi !
I am using Dazzle DVC-II for video capturing file captured through DVC -II in (Mpeg2) was working fine with MY-DVD software(No problem with video & Audio) . Now I am using Video Pack5.0 my DVD is working fine with menus( Back ground Audio is there in menu) but no audio in Video. while importing Mpeg2 file video pack shows no audio in both channels but if u play mpeg2 file in video pack audio is coming ok .If i use Mpeg1 file for DVD authoring DVD plays OK with audio.
Sounds like the source may not be quite right, If you make a image then you can test it with the VCD emulator before you make the disk.
Try loading the mpeg into TMPGEnc Merge & cut
Save out another copy of the full mpeg 2, and play it, if that’s OK try that with VP5
Authored DVD plays 3 seconds audio/No video
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 6th Jan 2011, 14:26 -
Video and audio are out of synch when authored
By edong in forum Authoring (Blu-ray)Replies: 2Last Post: 9th Dec 2009, 23:39 -
no audio when DVD authored
By shaolin2006 in forum Authoring (DVD)Replies: 6Last Post: 31st Aug 2008, 12:39 -
Software to make sure the audio and video of a authored dvd are in sync?
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2007, 07:13 -
Audio Delay in Authored DVD
By deathwalker in forum AudioReplies: 4Last Post: 21st Aug 2007, 20:42
