I've been expressing the bitrates in the 'settings' on 2 pass VBR as
min 0
max 2500 (values are not correct, just an example)
avg 1500
But I noticed that in one of the guides they are expressed as
1720000
2564000
0
Am I doing anything wrong here??? I havn't changed the 'eenironment' setting from it's default. Just want to make sure I'm not making a collosal mistake entering bitrates.
My Pioneer is good up to 2500KB/s exactly how do I express this in TMPG as an example?
Roveer
your not doing anything wrong. One is bits per second and the other is kbits per second. Under option\environmental settings in TMPGenc you can select which one you want to enter the bitrates in. As long as you realize the difference it doesnt matter which one you use.
[SOLVED] TMPGEnc DVD Author doesn't like VBR??
By Taeran in forum Authoring (DVD)Replies: 5Last Post: 19th Sep 2008, 18:11 -
Bitrates and CBR/VBR on Toshiba recorder - explanation?
By moxiecat in forum DVD & Blu-ray RecordersReplies: 7Last Post: 15th Jul 2008, 11:20 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
mpeg 4 realtime bitrates vs multipass mpeg-2 VBR
By miamicanes in forum Capturing and VCRReplies: 5Last Post: 9th Sep 2007, 21:37 -
VBR encoding problems with TMPGEnc 4XP
By maccool111 in forum Video ConversionReplies: 2Last Post: 8th Jun 2007, 04:42
