Are there Digital Video Recorders out there and are they worth buying? I've seen the vcd recorders but i'm thinking something like a vcr but digital where it captures to a harddrive and then you could somehow retrieve it through a network card. Instead of using your computer...
Big_Jit
The replay4000 and later models are designed to share video with other replays over a network. There are ways to trick it into thinking your file server is another replay, so if you're a techie at heart you could probably go that route.
There are also ways to hack a network card into a tivo, and there are ways to extract data off the various units hard drives by pulling them out and dumping the data with a PC.
Or you can build your own PC based pvr. ShowShifter is great for setting up a dedicated (or not) PC based PVR box. It's a little weak in the EPG department, but otherwise full featured.
If what you really want is to digitally record and archive stuff off tv, as opposed to simply timeshifting programs, then a DVD recorder might be a better choice. It would cost about the same as a decent PVR + subscription, but you'd be buying lot's of blank dvds at $1-$2 each.
BD / DVD Digital Video Quality as compared to Uncompressed RAW video.
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2010, 09:11 -
need some advice on some svhs and video cassette recorders
By gnrforever in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 16:57 -
What digital video format compares to Digital 8?
By jungleexplorer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Dec 2009, 16:00 -
Stand alone recorders; more of a problem than PC recorders?
By videobruce in forum DVD & Blu-ray RecordersReplies: 24Last Post: 13th Nov 2009, 12:27 -
DVD Recorders when analog switches to digital?
By primus_fan2001 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 17th Oct 2007, 14:03
