What exactly does Mask top, bottom etc etc do exactly?
If I clip part of a video file and mask what I cliped, I get exactly the same output after encoding as if I just clipped the video and encoded??
Help
Clipping cuts the edges off, changing the dimensions of the video. Masking cuts the edges off but replaces them with a color (defaults to pure black), leaving the dimensions unchanged. If you mask edges out instead of clipping them you won't screw up the aspect ratio if you're encoding to VCD/SVCD.
Thats exactly what I thought the masking did but I tried a couple of test encodes ,one with masking on & one with masking off, the resulting Mpegs were both the same?? so I was a little confused.
Thanks for the reply
Cheers -
Well, I haven't done it in a long time but clipping without masking only makes sense if you have a letterboxed source (such as from a camcorder that does not support anamorphic widescreen) and want to produce an anamorphic (S)VCD to preserve quality and/or supress scan line visibility on the CRT. Since anamorphic encoding does expand the picture by the factor of 1.33333 on the vertical axis you should only clip 12.5 % of the total number of vertical pixels even if that leaves a small black part remaining on 2.35 : 1 movies.
TMPGEnc Xpress - Clip Settings - No setting for 8:9 PAR
By terpsfan101 in forum Video ConversionReplies: 13Last Post: 17th Jun 2012, 04:28 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53 -
Background clip from movie - TMPGEnc DVD Author 3
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 11th Sep 2007, 02:02 -
Correct Terminology for a menu frame that shows a clip from the movie
By gayclarke in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2007, 08:19 -
how can I create mpeg2-TS clip composed of one (only one!!!) black frame?
By mb508 in forum EditingReplies: 3Last Post: 4th Jul 2007, 15:04
