    Aug 2002
    Philippines
    my grandpa bought me computer from the ads in tv. the one featured at http://www.tigertv.com/, my problem is i dont know what kind of cd-rw drive this copmuter has. i have tried reading all the manuals that comes with it, but there is nothing about the dvd drive and the cd-rw drive. does anybody have an idea? and pls tell me how and where to start. my goal is to transfer vhs to vcd. i already know the part where i need a capture card, coz my copmuter back home has a DV500 and a TEAC cd-rw, but i havent tried transferring vhs to vcd yet. pls tell me more about where i could get cheap and good capture card too.
    thank you very much.
  2. I don't think it really matters what kind of burner you've got, but more what burning software you use.
    Personally, I use Nero for mpeg burning and CDRWin for bin/cue burning.
    You should be able to tell what type of burner you have by looking at your hardware profiles through the control panel.
    Get yourself into the how-to manuals on this site. A few months ago I couldn't do any of this stuff, but now, I'm not too bad at it!
    You should experiment at first, my advice is buy a big load of cheap CD-R's, you'll probably make a lot of coasters at first!
    Make sure you read the guides here though, they really helped me out.
    Good luck
    Billy
    Jul 2002
    BATON ROUGE, LA - U.S.A.
    start menu-->control panel-->(make sure you're in classic veiw)system-->hardware tab-->device manager now click on "DVD/CD-ROM drives" . you should now see your drive name.
    Where I walk, I walk alone. Where I fight, I fight alone.
