I have just downloaded half of a film as an avi and tried to play it but it will not play. I have downloaded the Codecs and I just want to watch the film either on my computer on my my dvd player. can someone please help me? I want to burn it to vcd.
its a separate avi coz theres a part 1 and part 2, part one on one vcd, part 2 on the other?
if it doesn't play on your pc in WMP then you won't be able to make a vcd. do you have the nimo codec pack? as it has most codecs. if you have nimo installed and it still does not work,then i suggest opening it up in vdub and check the file info to see if it is some sort of weird codec. 8)
buttons on JVC XV-N50 dont work
By schlep in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Jan 2012, 23:59 -
Trouble with audio from mobile. Used to work fine. Dont know what happned.
By UmmAddan in forum AudioReplies: 5Last Post: 6th Jan 2010, 10:13 -
Restored videos dont work!
By BVG in forum Video Streaming DownloadingReplies: 5Last Post: 7th Jan 2009, 20:50 -
DVD menus and RTMs dont work right
By shashgo in forum Authoring (DVD)Replies: 0Last Post: 20th Dec 2008, 13:54 -
Remotes dont work under MCE 2005
By Annex in forum Media Center PC / MediaCentersReplies: 3Last Post: 12th Jun 2007, 08:30
