    May 2002
    MONTREAL - CANADA
    Difficult requirements multiple audio tracks:Adding second audio stream When I used then DVD2SVCD (D2S109B2) and I put the two audio (english and the second audio is french) everything works perfect.After everything is finish (encodage). I have 4 MPEG stream for svcd.
    MY PROBLEME IS THE no second audio. When I go to play on my STANDALONE (DV -444 pioner) I have the first audio is ok BUT NO AUDIO on THE SECOND ????????
    IF i RETURN ON MY PC AND I TAKE TPGENC AND CHOOSE DEMUX I HAVE ONE VIDEO AND TWO AUDIO ???
    OR SOMETIME MY FIRST CD (SVCD) I CAN PLAY ON THE STANDALONE I HAVE THE TWO AUDIO ON IT AND HEAR BOTH AUDIO .And THE REST OF THE CD CAN't HEAR THE SECOND AUDIO ?
    Why can't play the second audio .Is the probleme in the sowftware or the sound card or engraver.
    I USED 112,128,192.224 BITRATE AUDIO
    IF IT WAS THE DV -444 PIONNER -THE PROBLEME ????????
    SOMEBODY HAVE ANSWER FOR IT
  2. ]Try to play the SVCD on PowerDVD (software playback), if you get the second audio track, that feature is not avalaible on your DVD player, if it don't work, you have done something wrong.
    The pioneer dv-444 supports selectable svcd audio tracks, I have one myself and it works perfect.
