One simple guestion. does it make any difference in quality if a DVD rip is done in Divx in a low bitrate(2000) if you reencode it in a higher bitrate (6000/8000) for a DVD?
From a 2Mbps capture, if you re-encode at 8Mbps rate, all you will have is a very good encoding of a 2Mbps capture.
Lost, or thrown away quality, can never be regained. -
The most bitrate you use, the most your image will look as the source. So, if you encode at 4000 for DVD from a 800 Divx, you get better quality than 2000 for DVD. BUT you will never be able to obtain better quality than the source. (But you can apply filters to improve your experience)
DVD Ripping, editing and Reburning with Maximum quality
By reccos in forum MacReplies: 5Last Post: 16th Nov 2009, 10:19 -
By reccos in forum MacReplies: 1Last Post: 16th Nov 2009, 09:30 -
Reburning dvd with mistakes in title
By johns0 in forum Off topicReplies: 5Last Post: 2nd Sep 2009, 14:39 -
ripping, editing, and reburning dvd
By ChEeZeBaLL in forum Newbie / General discussionsReplies: 1Last Post: 29th Mar 2009, 21:19 -
tmpgenc author 3.0 lossless reburning
By buckethead in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 10:00
