I was wondering if anyone knew if the DVCII can capture Digital Cable. There is a setting for DV.
If your Cable box has composite or s-video connections u can, or u can just plug the cables into the back of your TV, which most TVs come with those connections anyway.
Peace,
Zorin -
np, let me know if u need anything else, I have the same capture device.
Peace,
Zorin -
There is one more thing I was wondering about. If I cut the mpg I make VCDeasy wants to pad it on the fly. Have you found a way around this or do you even have this problem?
Hmmm...... haven't used VcdEasy yet, I've been using TMPgenc to do all my cut/merge for my movies, works like a champ with no padding.
Zorin -
That did the trick. I had been using moviestar to cut and was having problems with the resulting mpg. I'll just use TMPGrnc from now on.
How To capture video shot in both sp and lp on the same dvc
By ishwinderjauhar in forum Capturing and VCRReplies: 0Last Post: 13th Jul 2011, 09:40 -
Dumb question on DVC vs HD DV tapes
By arcorob in forum MediaReplies: 4Last Post: 17th Mar 2010, 21:12 -
Dazzle DVC 90 Capturing
By LangleyM in forum Capturing and VCRReplies: 2Last Post: 19th Apr 2009, 10:42 -
Better than Dazzle DVC-170?
By bmbsa in forum Capturing and VCRReplies: 5Last Post: 21st Sep 2008, 07:18 -
Can I load DVC Pro-50 bit
By Tom in HD in forum MacReplies: 2Last Post: 14th Jun 2008, 15:54
