Please can anyone help me...I'm new to DVDs.
I recently purchased a DVD and it plays fine on my DVD player at home (however the quality isn't great so I think it may be a copy of a DVD!) however when I come to play it on my DVD-ROM on my computer it won't work! When I put it in my CD-ROM it isn't recognized and when I put it in my DVD-ROM it opens Windows Media Player V7.01.00.3055 but when I try to play it I get the message: Cannot play back the file. The format is not supported. I have also tried using powerDVD but I get a DVD Error window pop up which gives the Error code 89030000 and the message: Unknown file format.
I have looked at the DVD-ROM using Explorer and I can only see one file. The file is "Track01.cda" and it is only 1kb in size. I tried to copy the DVD to my hard drive using CloneCD and I got three files: Image.ccd (1kb), Image.img (1Gb) & Image.sub (42Mb).
All I want to do is be able to play the DVD on my Pioneer DVD500M (on my computer) or/and copy the DVD onto my hard drive so that I can play it from there.
CAN ANYONE HELP ME PLEASE?![]()
I would get either windvd or powerdvd to play dvd's on your computer.
or, you might(I'm not positive on this) be able to get away with installing the mpeg2 codec, and then playing the dvd.what are you askin' me for...
I'm an idiot! -
i have the same problem...i also have dvd rom pioneer 500m that i just got on friday... i tried power dvd and i got the EXACT same error 89030000...i've tired several things like updating the aspi..but nothing seems to work...i couldn't even rip the dvd...i tried to use smart ripper but it said that the block is locked and its asking me to unlock it...i also tried to use clone cd with no success...i get 2 very small vob files
please let me know when you found a way to get around it.
thanks -
You should purchase or download DVD software players. I had the same windows media problems with dvds until i purchased Cyberlink PowerDVD, and now I run through DVDs (and ripped vobs) like a breeze. You might also want to download Kazaa (great program) from download.com to look for shareware DVD software, although it has a plethora of pirated software
hi there
yea...i tried several dvd software players like cyberlink power dvd, windvd, sasami2k, and videolan
i just can't seem to make any of them work...should i get a different dvd rom drive...which do you recommend...i just hope that if i get a new drive i wont have the same problems
Will the Black Magic Intensity Pro work with my computer?
By GranolaThins in forum Capturing and VCRReplies: 2Last Post: 15th Jan 2012, 00:35 -
dvd copied from HDD wont work on other players or computer??
By wundahoss in forum Authoring (DVD)Replies: 1Last Post: 8th Nov 2010, 17:34 -
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 19:16 -
My new Harddrive didnīt work, to weak computer?
By Espen in forum ComputerReplies: 6Last Post: 24th Sep 2008, 14:47 -
SONY Burnt DVD+R's Work Fine in Stand-Alone, But Won't Playback in Computer
By MYSTiCKWARLOCK in forum MediaReplies: 3Last Post: 13th Nov 2007, 03:27
