Subject nearly says it all: Which standalone dvd-players are capable of correctly reproducing anamorphic SVCDs? Please no hearsay, but own experience!
TIA
I always create anamorphic svcd, I have a TV, that I can set manually to anamorphic/normal input, so there's no problem there. I just set one av-input to anamorphic, the other to normal. I think there's no way to make it switch automatically.Originally Posted by inliner
Which player model do you use?
I too can switch my tv between 16:9 and 4:3 but I'm searching for a player which if it detects an anamorphic svcd will put out a true 16:9 image and no eggheads. -
When using anamorfic video the video recorder and player is standard 4:3 NTSC or PAL hardware. You simply make a correcting with the lens when recording, and with a wide screen when playing. Any DVD player can play anamorfic video as long as you have a TV set you can change the aspect ratio from 4:3 to 16:9. This is obviously not the same as HDTV, but standard definition TV with a aspect ratio of 16:9 using an anamorfic lens.
Yes, but it is my understanding, that there is a flag on the dvd or svcd, that tells the player to output the images as 16:9 and not as 4:3. Otherwise you get eggheads.
And I do not know, if all or only a few standalones support this feature with svcd discs .
Please correct me, if I'm wrong!
Is it possible to re-edit a non-anamorphic dvd to anamorphic?
By Beautiful Alone in forum DVD RippingReplies: 45Last Post: 22nd Sep 2011, 10:00 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 16:46 -
Wierd REWIND Problem... on standalones only!)
By taboo in forum DVD RippingReplies: 4Last Post: 16th Feb 2008, 22:29 -
DVD Plays fine on computer but is screwed up on standalones
By jalopy6 in forum Newbie / General discussionsReplies: 9Last Post: 14th Feb 2008, 09:17 -
anamorphic or not anamorphic
By cd090580 in forum Video ConversionReplies: 3Last Post: 23rd Jun 2007, 13:48
