Hi all!
This is the first time i post a question here and hope some experts could help me out. I started the VCD making recently, so i have a lot of questions. This is one of the most important one for me right now.
Recently I have obtained a few DVD Rips from somewhere, and now I would like to convert it into VCD. After several trials and errors, i have make a VCD of a hollywood movie. However, the problem is that since the original DVD Rip (AVI file) is in a 16:9 ratio, hence after converted into VCD, which fixed the dimension to 352 x 240, the whole movie has been elongated, and every characters seems so tall and thin (too bad... :<)
I have tried to change the output size in TMPGEnc, but after that the VCD player cannot even play it.
So my question is that if I want to add two top and bottom "black strips" and have the movie in the middle so that the ratio can be kept, what software do I need? How do you all tackle this problem?
Now I have TMPGEnc, Nero, Adobe Premiere. Are they good enough?
Any help is much appreciated!
	Me too .. there's options for stuff in TMPGenc but it's going to take a few try's to get it right... and at 12 hours a shot .... Help!
	Here's some info maybe it'll work, i'm trying it now.
 http://www.vcdhelp.com/tmpgenc.htm
 Select Other Settings
 Click on Advanced
 Change the Video arrange Method to Full screen (keep aspect ratio) if you wan't the movie to look exact the same as the video source.
 If you have a widescreen movie and you want it to be fullscreen(no borders) select instead No margin(keep aspect ratio) and TMPGenc will cut it.
	Also you can just stop it after a few minutes and look at the results...
 Mpg's can be played when they are incomplete.
	Looks like "full screen - keep aspect ratio" is the way to go to keep the wide screen just right....
 Under Setting / Advanced i have ...
 Non-Interlace
 Top Field first
 1:1 (vga)
 Full Screen (keep aspect ratio)
 And i turned off the Inverse Telecine.... it took a long time to do that the first time so trying without.
  Problem with Aspect Ratio in DVD FlickBy Dave_T in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2011, 23:07
  AVCHD to DVD: aspect ratio problemBy The Realms of Gold in forum Video ConversionReplies: 7Last Post: 22nd Mar 2011, 05:05
  VHS-DVD Screen Ratio ProblemBy Ozzyjim in forum DVD & Blu-ray RecordersReplies: 0Last Post: 16th Jan 2011, 23:27
  Aspect ratio problem with DVD coverted to MKVBy nick1977 in forum DVD RippingReplies: 23Last Post: 16th Nov 2009, 11:42
  authoring DVD - pixel-aspect-ratio problemBy Levina in forum ffmpegX general discussionReplies: 5Last Post: 22nd Mar 2008, 16:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
