I want to capture a 300k winmedia stream to a file. I don't care what kind of file because I'll find something to convert it if it's not compliant. But any utils out to do this? i've tried asf recorder and it doesn't handle certain types of winmedia streams or if they are using udp. just for an example like the music videos on launch.com.
what about realmedia or quicktime streams anytihng to capture them?
there is certain progs that will capture what is on your moniture and then on prog that will Cap the sound and its a lot of work and hard to do sometimes. I think the Video prog is Snapit or something like that
HyperCam does video and sound, and also lets you cap streams and desktop stuff, whatever you tell it to, in whatever codec you want (have installed)...
Does a good job too when you get your settings all nice and set up...
Home Media streaming
By Eyeopr8r in forum Newbie / General discussionsReplies: 5Last Post: 29th Nov 2011, 10:55 -
Intermitent failure when streaming from MS Media Streaming Services
By OshiDaro in forum Video Streaming DownloadingReplies: 0Last Post: 8th Dec 2010, 07:10 -
PC to TV streaming using HD media player
By mohit in forum Video Streaming DownloadingReplies: 4Last Post: 12th Aug 2010, 02:00 -
download streaming media?
By just in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2008, 22:59 -
HELP! How to Streaming more than one wmv file in Windows Media Encoder
By smcalpine in forum Video Streaming DownloadingReplies: 4Last Post: 16th Jul 2008, 09:19
