Hi All,
Does any one out there knows wat software can I use to create AVCD? I try a few but all write audio and data in a separate session, does any software able t write both data and audio into one session.
And also is there any software that can do a conversion from CDDA to DAT externsion?? Pls help me!!![]()
It's easy.
1. Process your video (mpeg file) into a Fireburner image (bin and cue) by using VCDImager with GUI.
2. Then use Fireburner to open the image file (cue file) and add audio wav files to the tracks after the beginning video tracks -- just drag and drop the audio files.
3. Now burn it with Fireburner.
*To watch the video, just pop it into a vcd/svcd compatible dvd player and push play.
*To listen to your audio cd, skip two (or more if you have more than 1 video files) tracks to play your music audio in a cd player. -
VCD Toolkit 1.0 can make proper VCD2.0 discs with CD-DA tracks. However, the Fireburner trick is quite clever too.
Regards.Michael Tam
w: Morsels of Evidence -
Hi thanks to both of your advice, but how abt coverting CDA tracks to DAT extension???
Trying to make AVCD/VCD with audio data
By Vejita-sama in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Aug 2007, 16:15 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 16:13 -
How will I make an AVCD with menus?
By zeldAIS in forum Newbie / General discussionsReplies: 19Last Post: 4th Aug 2007, 16:12 -
How will I make an interactive AVCD? [from newbies section]
By zeldAIS in forum Authoring (VCD/SVCD)Replies: 6Last Post: 4th Aug 2007, 16:10 -
HELP With Creating AVCD
By BinaryJustin in forum Authoring (VCD/SVCD)Replies: 1Last Post: 4th Aug 2007, 12:38
