I have the following software installed on the PC. My problem is TMPGEnc won't open any .vdr files created by VirtualDub. TMPGEnc tells me the .vdr file is not supported but I have installed the handler from VirtualDub and also registered the VFP plugin. Any suggestions?
TMPGEnc v2.57
VirtualDub v1.4.10
this took me ages to sort out & was driving me crazy!!
I think the thing that finally sorted it was copying a .dll called something like msvcrt70.dll into my windows/system folder.
In one of the 'how to' guides there is a section on troubleshooting the problem you're talking about:
http://www.vcdhelp.com/virtualdubframeserve.htm
if what's on that page doesn't sort you out, try the link at the bottom of the page for more details.
good luck - it's worth it in the end!! -
It worked! Copied it to the system32 folder and loaded like a charm. Thanks for you help.
edit: still unsupported
edit2: finally got it, invirtualdub when you have to save the vdr.. the name only is not enough you have to type .vdr yourself altough its already displayed n the scrollbox
Windows 7 64 bit files not appearing after they are created
By stantheman1976 in forum ComputerReplies: 1Last Post: 22nd Feb 2011, 23:10 -
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 08:26 -
How are ifo files created with only vob files?
By Han Solo1 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2008, 13:07 -
Only TMPGenc Support .vdr
By arturjose in forum Video ConversionReplies: 1Last Post: 15th Apr 2008, 23:04 -
How Do I Put A Custom, Created Slow Motion Clip Back In? (Virtualdub)
By WishMaker in forum EditingReplies: 8Last Post: 24th Oct 2007, 11:14
