I want to take a still picture and then make it an mpeg file for a menu in a VCD.
What is the easiest/best method to make a still frame into a movie?
Not only am I perfect but I'm Canadian too!
VCDeasy should be able to handle that for you.
Not only am I perfect but I'm Canadian too! -
I finally figured out in Vegas Video how to do it I made a jpg into a movie but its kinda blurry. Is that normal? Is there a better way to convert it?
I made it an avi with huffyuv compression. It looked OK when small but as soon as I made it full screen it was blurry.Not only am I perfect but I'm Canadian too! -
VCDEasy with the VCDImager GUI has to be the easiest...just select the image and convert. I havent tried any other programs for doing this, but its just so simple and quick that I cant imagine a better way. Its also good for creating chapters with entrypoints instead of creating a multisegment VCD which will introduce pauses on playback.
Well I have taken pictures and made into movies and I have used Vegas Video's text tools to make menus. All seem fine at 353x240 but at a larger size they appear blurry on my PC unless I make them a bigger size which won't work for a VCD.
I imagine that would mean that they would be blurry on a VCD. Is that correct and if so how can I get them sharper?Not only am I perfect but I'm Canadian too!
Making a movie with Canon Legria clips
By Clare - the Witch in forum Newbie / General discussionsReplies: 10Last Post: 7th Feb 2012, 16:46 -
Lossless Video Compression for Movie Making
By Sparehead01 in forum Video ConversionReplies: 4Last Post: 6th May 2009, 18:43 -
Movie Making with Google Earth (GE)?
By solarblast in forum EditingReplies: 8Last Post: 7th Jan 2008, 11:20 -
Making a homevideo more like a theater movie
By qazwsx16 in forum EditingReplies: 12Last Post: 4th Jun 2007, 13:56
