I have just burned a media file to cd in the form of a *.vcd with Nero and some of the quality when I played it in my external cd rom was lost. Which media form should I be converting to so that I would get good quality when playing in the external cd player VCD, SVCD, or DVD? Also, If the type of media selected doesn't matter should a file be kept as two parts (2 avi's instead of one) or if the files are joined will the quality still be the same or will it lose quality?
Any input would be appreciated.
Thank You.
Results 1 to 1 of 1
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
burning
By michael simmonds in forum MacReplies: 3Last Post: 25th May 2010, 02:50 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
