Why the cce 2.5 make the message error "cannot find apropriate codec for dsvd"?![]()
Couldn't even wait half an hour? (I understand the feeling)...
Check your drivers and codecs... my guess is you're attempting a DivX encode, but may not have THE codec you need (there's 3.11, 4, and 5 now, all different).
Just for kicks, try installing the Nimo codec pack, found under the "Tools" section. I believe it includes pretty much any of the codecs you'll need.
Or... are you doing AVISynth?
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 14:25 -
Problem installing pvr 250 on Windows vista 32 mce
By heman28 in forum Capturing and VCRReplies: 2Last Post: 10th Mar 2008, 22:18 -
cce video bitrate problem
By DSLGuy in forum Video ConversionReplies: 11Last Post: 16th Feb 2008, 13:53 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
Hauppuage PVR 250 problem
By jwfc in forum Newbie / General discussionsReplies: 4Last Post: 26th Sep 2007, 15:40
