I have some avis i want to record to a vcr can some one tell me how to do it with Tv out
If you bump posts a few hours after they were made, you will get no response
Use tvtool and disable macrovision www.tvtool.de
Connect to your tv/vcr with either rca or svideo and from your souncard
Play the movie and record
and please wait at least some days before bumping. -
how do i connect to vcr with S-video, i have a tv with s-video but i don't know how to record it to vcr
If your vcr has no s-video input you will need a converter. Go to radioshack and ask for a "female s-video to female composite video convertor".
TV Respects Me! -
Here's the way I do it. Connect your svideo out to your tv, connect audio out cables to tv. You may need a stereo "y" adapter cord to get both audio cables in, if not just uplug in the mono cable jack.
Connect your vcr to tv with RCA cables, if your tv has a/v out jacks then plug in there.
Right Click on desktop, properties, advanced, click clone view, should see computer screen on your tv. You may have to toggle your video1,2 switch on your tv to get picture, just as you would to see a dvd or video.
Play the avi's with Divx Player or Windows Media Player, you shouldn't have to worry about macrovision if it's an avi. Press record on your vcr.
Hope this helps.
P.S. it helps if you have a tv with multiple a/v input/output jacks. -
i got this http://www.svideotorca.com/prosvideo6.html. i could get the videio to show up but i can't get the audio to work, i plugged it in where my speakers suppose to come out. still no sound , does anyone know why
NVIDIA GeForce 7300LE
By mccoady in forum ComputerReplies: 26Last Post: 18th Jun 2009, 22:22 -
GeForce 7300 SE S-Video`
By Dan Dare in forum Newbie / General discussionsReplies: 1Last Post: 22nd Nov 2008, 16:29 -
Geforce 8400 GS
By zoobie in forum ComputerReplies: 1Last Post: 5th Nov 2007, 04:02 -
Geforce MX 400 - 64mb...is it the problem???
By fgtan in forum Media Center PC / MediaCentersReplies: 4Last Post: 28th Oct 2007, 22:54 -
nvidia geforce 7800gs AGP V's geforce fx 5500 AGP
By stackner in forum ComputerReplies: 5Last Post: 15th Jun 2007, 15:22
