I am trying to get something really usable to test out my 200i and my Pioneer DV-C503, but the download link has said the limit has been exceeded and try again tomorrow. Well, I seem to get to it after it has been exceeded every time.
Anyone?
Thanks.![]()
http://www.darim.co.kr/ftp/mpegs/fball.m2v
no audio
ftp://ftp.darim.co.kr/pub/mpegs/ more on thier ftp site
snell & wilcox have many on thier ftp site ..
http://www.overlaytools.com/demo/profiler6Mbps.vob
very good -- exact dvd spec sample
http://www.overlaytools.com/demo/navispro6Mbps.mpg
another one but in mpeg format.. again to dvd specs
http://www.stream-video.com/demo/dazzle6Mbps.vob
dazzle encoded mpg
http://www.overlaytools.com/demo/DIVAMPEG2.mpg
dvd sample mpeg -- Karaoke kit -
I finally got in and downloaded it from here. Funny thing, I burned it, and the DVD-VCD sample doesn't even play, and the DVD-SVCD plays on only 2/3 of the screen starting at the left, but it does fill up the screen horizontally (sp?). I will have to keep that in mind, and I will continue to use DVD+RW's until I get this down.
jeepman: did the dvd trailer work? the dvd-vcd and the dvd-svcd may not work on all players.
BJ_M
The samples and templates on this site are DVD compliant, if he is looking for samples of MPEGs that were comverted to a DVD format or a Rip that was converted to a DVD format then this site has that. So I would still suggest that they check the site if for nothing else then information on DVD related conversion process. I know when I first started to look into using DVD-R's and DVD conversions the more information I had the better it was for me to follow the process.
Aloha
Bud -
Yes, that worked fine. I recall seeing that same trailer when I did a test SVCD, and the DVD version doesn't get blocky and played great. The SVCD version I think was at 3500Kbit, which my Pioneer can't handle without choppy audio.Originally Posted by Baldrick
Mirror copy of Pinnacle DVD
By Straightlegger in forum Authoring (DVD)Replies: 2Last Post: 1st Feb 2010, 12:40 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 11:26 -
Direct download mirror link to lastest version ffdshow
By roma_turok in forum FeedbackReplies: 1Last Post: 17th Dec 2008, 05:08 -
Epson R200 how do i copy a Mirror type dvd?
By kentucky in forum MediaReplies: 10Last Post: 15th Feb 2008, 16:59 -
Such thing as dual link to single link DVI-D cable?
By Mizkreant in forum DVB / IPTVReplies: 1Last Post: 14th Jul 2007, 06:51
