Hi,
I have a good quality MPEG2 video and audio stream. I have to make some changes to it and I need help with what programs to use. My goal is not to re-encode it.
My source is a mp2 with a resolution of 544x480 (NTSC, 29.9 fpm). Weird size. Anyhow, I need to convert it to DVD standard, 720 x 480.
Also, the audio is out of sync with the video and I now exactly now many ms it is off by.
So I'm looking for a good way to resize and mux my source without re-encoding. Any help is appreciated. Thanks,
ICON
Would be easy to do with TMPG ...if you wanted to re-encode....not sure there is any way around that though
Does changing frame rate make audio out of sync?
By aznbennet in forum AudioReplies: 2Last Post: 11th Sep 2011, 03:32 -
Video & Audio is out of sync after muxing
By Spettro in forum EditingReplies: 2Last Post: 2nd Dec 2010, 12:11 -
MKV Muxing Audio Out-of-Sync with Video
By Cube11 in forum Newbie / General discussionsReplies: 0Last Post: 26th Jun 2008, 14:27 -
Audio CBR out of sync after muxing + stuff
By Darius_bd in forum Video ConversionReplies: 4Last Post: 11th Apr 2008, 08:50 -
Audio Sync Issues - Can't find resolution!
By cl0nd0n in forum ffmpegX general discussionReplies: 4Last Post: 24th Oct 2007, 22:40
