  1. I can burn an MPEG2 file to a cd, no problem. But what I can't figure out is how to burn an MPEG2 file with audio to a cd. I want this on a cd to save it and reload onto another computer. And on that note, can someone explain the "MPEG2 program stream" setting to me? I can't figure out what this does exactly. To burn a DVD I have to use the "elementary stream" and let my DVD software find the audio, can't seem to find any program that will even recognize a "program stream.
  2. C'mon guys! I know it's probably too simple or dumb a question, and you've probably answered it a hundred times, I have really have looked, and can't find the answer. Please help.
  3. Banned
    Jun 2001
    UK
    Mmm, what ?
    You have no audio, well start from the beginning I say
    Don’t know your source, assume you used TMPGEnc and loaded a DVD template, PAL/NTSC then used that with your authoring program ?
    What was the source, did it need separated audio ?
