i convertedmy first avi file to mpeg yesterday and it worked perfect, the sound and everyting was right, but i tryed it on a different movie today and i did the same exact thing but there is no sound at all?, can someone help me?
You need to give us more information.
Were you following a guide on this site?
Which programs did you use to do the conversion?
Did you download the AVI file from the internet?
Did the AVI file have sound when you played it directly? -
Fill out your "computer details" while you're at it, it might help you out in the future.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
http://www.vcdhelp.com/divxtovcd.htm#audio
Use this guide to make a WAV file
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 11:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
