I'm using a ATI AIW 7500 on Win2000 and installed the btwincap.sourceforge driver but do not know how to tell if my capture software is using it? In device manager the new driver is showing up but with a ! next to it. So how do you tell if the new driver is being used?
The ! next to the driver is indicating that whilst the driver is installed, it is not functioning correctly. I would guess that it is conflicting with the existing ATI drivers installed on your system.
It is very difficult to get multiple drivers operating correctly on a Windows system, usual practice is to deinstall the existing drivers and then reinstall the new ones. -
If you want to use different drivers than the ATI ones, you MUST remove those first....
Virtualdub 32bits error: cannot connect to the desired capture driver!
By Cauptain in forum Capturing and VCRReplies: 3Last Post: 21st May 2011, 11:17 -
ATI MMC 8.8 - capture driver not listed in registry?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 10:13 -
capture with twain driver
By zalves in forum Capturing and VCRReplies: 4Last Post: 27th Mar 2009, 14:46 -
A tricky Driver for Capture Device Needed
By Digiliz in forum Capturing and VCRReplies: 9Last Post: 8th Jul 2008, 11:26 -
saving driver specific parameters for next capture
By hpishva in forum ProgrammingReplies: 0Last Post: 6th Nov 2007, 13:02
