I'm trying to deinterlace a hybrid avi stream (by hybrid I mean has interlaced parts as well as telecined parts.) I found that the field deinterlace filter in avisynth works great for the interlaced parts and a telecide/decimate combo works great for the telecine'd parts. Now what I would like to do is set up an avs file so that avisynth only deinterlaces a certain number of frames and then telecides/decimates and another set of frames. I want this deinterlace, telecide/decimate to alternate for a couple of cycles. In other words, I would like avisynth to do certain things to certain parts of a stream. Is this even possible?
I can do what I want to do if I chop up the main stream into 9 parts, make an avs file for each part and then have avisynth batch process all these files. I would rather just frameserve one big file.
Thanks for any help, pointers, ideas or criticism!
Results 1 to 1 of 1
Problem with my mixer! I need some assist from a guru!
By hellfire45 in forum AudioReplies: 8Last Post: 17th Jan 2011, 02:54 -
Pleading for guru advice DVD recorder w/digital tuner, hdmi
By arlene in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Nov 2009, 10:55 -
Need an Adobe Encore DVD Guru for this one....
By sdsumike619 in forum Authoring (DVD)Replies: 2Last Post: 9th May 2008, 19:24 -
GURU feedback needed: web server encoding and .flv size
By lucite in forum Video ConversionReplies: 4Last Post: 15th Feb 2008, 18:28 -
simple request to video guru...or is it?
By wormdog88 in forum EditingReplies: 4Last Post: 12th May 2007, 00:57
