Hello Everyone, I am looking for a template which can which one hr digital video in SVCD form onto one CD. My source file is in 720x480 format. Thanks
I do this often.
pick the standard svcd template, and use the unlock template to
let you change things.
I usw cq=77, max bitrate=1600, min=300
I also set the audio bitrate to 192kbps
everything else can stay the same
turning on noise reduction may marginally improve picture quality
but increases encodeing time a lot
turning on interlacing looks fine on a non-progressive tv
and seems to decrease encoding time
I usually frameserve from flask or xmpeg and use that
program to do the bilinear resize and audio downconvert -
Set the average bitrate to 1600 2 pass VBR in TMPGenc for 1 hour that will fill the 80 minute CD to the edge.
Template for effect.
By tomofthefuture in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2011, 17:04 -
AVC/H.264 Blu-Ray Template for TMPGEnc 4.0 Xpress?
By CubDukat in forum Video ConversionReplies: 8Last Post: 22nd Sep 2010, 11:52 -
A simple, easy to use website template?
By sdsumike619 in forum ComputerReplies: 2Last Post: 23rd Apr 2008, 06:02 -
Printing Template
By mleb33 in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 09:09 -
Template selection in CCE...
By hiimbored in forum DVD RippingReplies: 5Last Post: 28th May 2007, 19:54
