  1. Hi again,
    I burned the DivX avi to VCD using nero, and tested it in both a VCD player and a DVD player. It's fine, but it's very stuttery every 20 frames or so. It's consistent as well, not just when there's a lot of motion going on.
    Can anyone give me some advice?
    These are the details of the movie:
    DVD Decrypter => XMPEG => Nero 5.59
    Used DivX 5 in XMPEG. NTSC 352x240, 1-pass CBR @ 1300kbps. Audio is 192kbps 44100hz. This all in XP.
    Thanks a bunch,
    E
  2. The NTSC I noticed may be the problem. Is it a NTSC compatible player. Or is it mainly a Pal Player you have.
  3. Hi, thanks for the reply.
    It's an NTSC movie, but the player supports both PAL and NTSC.
    I've read another post about the 'Swap Fields' option and this seems to have helped.
    Regards,
    E
